[SOLVED] Align RCE-BL80A Throttle Frequency
amal2029
Could anyone advice the correct throttle frequency for Align RCE-BL80A ESC to be used with Spirit setting?
ESC specs sheet shows only the High and Low operating range as 1940 - 1100.
Is it acceptable to leave the default 60Hz value in the Spirit setting?
Thank you,
Amal
you can leave 60Hz. If not using Spirit Governor then it is the best frequency to be set.
amal2029
Mr.Tomas,
Thanks for the advice. I shall not be using governor feature for the moment. So, I'll use it with 60Hz value.
Regards,
Amal
