[SOLVED] Align RCE-BL80A Throttle Frequency
Posted: Tue 21. Dec 2021 5:58:36
by amal2029
Could anyone advice the correct throttle frequency for Align RCE-BL80A ESC to be used with Spirit setting?
ESC specs sheet shows only the High and Low operating range as 1940 - 1100.
Is it acceptable to leave the default 60Hz value in the Spirit setting?
Thank you,
Amal
Re: Align RCE-BL80A Throttle Frequency
Posted: Tue 21. Dec 2021 9:24:05
you can leave 60Hz. If not using Spirit Governor then it is the best frequency to be set.
Posted: Tue 21. Dec 2021 9:48:58
by amal2029
Mr.Tomas,
Thanks for the advice. I shall not be using governor feature for the moment. So, I'll use it with 60Hz value.
Regards,
Amal
