[SOLVED] Spirit GT governor, throttle output unchanged
Posted: Sat 02. Apr 2022 17:04:54
Hello again gents.
Raptor 90 3D, OS 91 HZ, Hatori muffler.
The engine is still tuned slightly rich after breaking in a new piston ring and a honed sleeve.
I gave the Spirit governor another try, and I can't get my head around what it's doing and what I am seeing in the log.
In flight on climbout the heli does climb very well, but on tictocs it can't sustain the rpm over some time.
Almost halfway in the flight I landed to adjust the needle a bit, and when flipping it into IdleUp 1 and 2 again there was no difference in sound between them. The rpm also sounded quite higher than before, so I think the governor didn't engage?
I landed again and felt the backplate to feel the temperature, but it was fine.
Up again and this time the governor took control, a lower rpm and there was a difference between Idle 1 and 2.
I looked at the log with the RPM and Throttle output, and there is something weird. The throttle output curve is very flat and "unresponsive", so I don't know what is causing this?
In the Governor/Throttle settings the requested rpm are 1700 in Idle1 and 1900 in Idle2.
The logging rate is set to 50Hz.
If anyone could shed some light over what I am doing wrong, or what the GT is doing wrong it would be very much appreciated!
I attach a screenshot of the Advanced Flight Viewer and the Governor/Throttle settings.
The red colour is Throttle output and the green is RPM.
If you need anything else just let me know.
Cheers guys,
Orjan.
Cheers guys,
Orjan.
