Page 1 of 2
Wrong Altitude Values after update to 3.4.0
Posted: Thu 09. Jun 2022 18:02:29
by sacha
Hi
System: Spirit GTR and Geolink.
After upgrading from 3.3.3 to 3.4.0 altitude values are wrong. Way to low.
Wrong on the telemetrydisplay on the jeti remote controller.
Also wrong on the jeti log chartviewer on the jeti remote controller (DS16)
Also wrong in jetistudio.
I attach two screenshots from jetistudio, one before upgrading to 3.4.0 and one after the update.
As always thanks for your help
Sacha
Re: Wrong Altitude Values after update to 3.4.0
Posted: Fri 10. Jun 2022 14:11:08
by Heligator
Greetings
As i read this post, i found out that i have the same Problem. After update Spirit System GTR to 3.4.0 including the radiocontroll software (BIN)
Altitude values are definitly wrong. My messurments in the log was between +-/4m what can't be truth.
Before the 3.4.0 Spirit update, all values were ok.
So any Guys have the same Problem ?
Posted: Fri 10. Jun 2022 21:46:44
by proctormw
My altitude values all look to low also. I have geolink, updated bin and Spirit GT and with 3.4.0 update
Posted: Sat 11. Jun 2022 7:11:02
by HeliMLM
no problems here... did play around with the great new rescue engaging options - so I checked the logs afterwards to see if manual rescue could have any effect on auto rescue height. perfect height from 0 to 33m....
Posted: Sat 11. Jun 2022 8:10:56
by sacha
@HeliMLM
Are you using a SpiritGTR and a GeoLink ?
Sacha
Posted: Sat 11. Jun 2022 13:43:02
by HeliMLM
... no, just Spirit GTs & GTRs!
Posted: Sat 11. Jun 2022 16:46:55
by Mattes61
HeliMLM,
Sorry for saying that, you have not the same configuration - so it is not the same and not very helpful - sometimes I have the feeling that you are sponsored - maybe I am not right, but if two or three people have the same problem, then its not an coincidence -
Posted: Mon 13. Jun 2022 12:29:44
by sacha
In my debugging process i disabled the geolink in the spirit GTR configuration.
As you can see on the screenshot, altitude values are normal again.
Summery for 3.4.0
Spirit GTR + Geolink:
Speed, lon and lat values are ok.
Altitude: broken
Spirit GTR without Geolink:
Altitude: ok
Other values not available because geolink is not used anymore.
I hope there will be soon a fix available.
Greetings
Sacha
Posted: Mon 13. Jun 2022 16:01:01
thank you for the message.
We are looking into it. If there is something wrong we will fix it.
Posted: Mon 13. Jun 2022 18:08:27
by sacha
Many thanks.
If there is anything i can do to assist, let me know.
Sacha
