Page 1 of 2
[SOLVED] Problem Geolink
Posted: Tue 05. Jul 2022 20:40:14
by Dieter
When actived Position Hold and Altitude hold the heli goes down to the ground. Activated RTH, the heli fly back to start, and then similar altitude hold to ground. Pitch has no effect.
30.06.2022-mitGeo.4ds
(255 Bytes) Downloaded 85 times
Have anyone an idea.
Thanks Dieter
Re: Problem Geolink
Posted: Tue 05. Jul 2022 21:02:54
you can try to set Vertical Correction Gain for GeoLink to 50%.
Instead of engaging more features, please engage only one to see if result is better.
I can see that you have more functions enabled, so it is important to try just one. Because Altitude Limit can interfere with Altitude Hold.
Re: Problem Geolink
Posted: Tue 05. Jul 2022 21:50:04
by Dieter
Ok i will try it, but the same configuration has worked before.
Dieter
Re: Problem Geolink
Posted: Thu 07. Jul 2022 18:06:28
by Dieter
Today i habe tried only Altitude hold and gain 50%. No success. then i started analysis.
Re: Problem Geolink
Posted: Thu 07. Jul 2022 18:08:23
by Dieter
What means the screenshot "Einstellungen X,Y,Z"
Dieter
Re: Problem Geolink
Posted: Thu 07. Jul 2022 18:52:12
the problem with altitude hold is not in vibrations, but possibly in GeoLink mounting or servo configuration.
It is important that when you enable Servos - Subtrim (tuning) all servo arms will be in the center of their travel.
At the same time there must be 0 degrees between main blades.
Can you check this?
Re: Problem Geolink
Posted: Thu 07. Jul 2022 20:22:48
by Dieter
Here is my geolink mounting. Servo konfiguration will be check next time.
Thank you
Dieter
Re: Problem Geolink
Posted: Fri 08. Jul 2022 15:10:04
by Dr.Fleming
Hi Dieter, you maybe touch when you setup the Spirit, in the windows "Servo Travel correction" ????
Dieter wrote:Here is my geolink mounting. Servo konfiguration will be check next time.
Thank you
Dieter
Re: Problem Geolink
Posted: Fri 08. Jul 2022 18:50:37
by jjuk
When activating, try to place the pitch stick at zero pitch. Both of mine also drops about 3m when first activated.
Re: Problem Geolink
Posted: Fri 08. Jul 2022 21:14:07
by Dieter
I have controlled my servo configuration, then test on field, no success.
Then i tried this:
#jjuk write. When activating, try to place the pitch stick at zero pitch. Both of mine also drops about 3m when first activated.
And it works not bad. What is wrong in my system?
Dieter
