[ Version 3.4.4 released! ]
Posted: Tue 03. Jan 2023 13:21:23
New version 3.4.4 released!
New firmware for the Spirit units is available online directly through the software.
NOTE: No changes in the settings are needed after update from the previous version 3.4.3.
- Increased Gear Ratio range in the Telemetry window:
- Gear Ratio range was increased to allow a proper settings (1 - 32 ratio).
- Goblin RAW 420 and similar models can configure correct Gear ratio in the Telemetry window, same as in the Governor window.
- Spirit Settings for Linux on QT5 library:
- Spirit Settings software is using more recent library now.
- Compatibility on a different Linux distribution was improved by this change.
- Spirit Settings for Mac OS updated:
- Spirit Settings on some Mac systems was not showing GeoLink map properly.
- Libraries for Apple Mac systems were updated to support more image formats.
- Spirit Settings on a small screen:
- Spirit Settings with screen resolution such as 1440 x 900px will fit all content properly with all Operating Systems.
- HobbyWing v5 telemetry:
- Telemetry variables were showing 10 times lower values on some v5 ESCs.
- Current and Capacity measurement was fixed.
- GeoLink logging:
- Logging is enabled when unit will detect vibration level 3% and more.
- With some models logging was interrupted when vibration level was too low.
- RealTime logging:
