[SOLVED] Spirit2 - fport - No telemetry
jjuk
I have set up a Spirit 2 (v3.5.0) with a r-xsr f.port receiver running ACCST v1.
The spirit 2 is receiving channel information correctly. It's fully operational.
The spirit 2 doesn't seem to be sending any telemetry information back to the radio, also the OpenTx scripts are not loading (because the spirit 2 isn't sending telem back to the radio).
we have exactly this receiver and it works with F.Port well, including telemetry and integration.
Do you have something else connected to F.Port bus?
Is F.Port receiver type configured in the Spirit unit?
MegaHz
Make sure you have the connector plugged in the right way. The exact situation happened to me. in ACCST you should be on S.PORT technically
jjuk
My r-xsr is connected as follows:
https://oscarliang.com/wp-content/uploa ... 24x591.jpg
Code: Select all
Un-inverted smart port -> Spirit 2 ELE/PIT/AIL top pin
RX Power               -> Spirit 2 RUD top pin
RX Gnd                 -> Spirit 2 RUD bottom pin
Receiver is set to "FrSky F.Port"
I have full control, but no telem.
Maybe problem is here:
RX Power -> Spirit 2 RUD middle pin
jjuk
Sorry that was a typo. The power is connected to the centre pin.
Vector
Did you updated r-xsr with last FW ? And did you put rx in f.port mode?
jjuk
Here are all the software versions that I'm using:
Spirit 2 v3.5.0, 4ds file attached.
500x fport with stab.4ds
(255 Bytes) Downloaded 133 times
R-XSR:
I'm running RXSR-FPORT_LBT_ACCST_191128.frk from here:
https://www.frsky-rc.com/wp-content/upl ... 191128.zip
The receiver is showing a green and a blue LED, which I believe means green=bound, blue=fport.
Transmitter:
Running OpenTx 2.3.14, and Spirit integration https://www.spirit-system.com/dl/opentx ... 4.3-en.zip
I have full channel control of the Spirit 2, all channels are working, so the receiver must be outputting f.port to the spirit, but the spirit isn't sending telem to the receiver.
Vector
Try this ACCST D16 v2.1.0, ACCST D16 v2.1.1(F.Port firmware update only )
GT 3.5 + R-Xsr 2.1.1 LBT and EdgeTX 2.8 integration 3.4.3 everything works great.
jjuk
Just flashed the transmitter to ACCST v2.1.0, and the r-xsr receiver to "RXSR_ACCST_2.1.1_Fport_LBT.frk."
https://www.frsky-rc.com/wp-content/upl ... v2.1.1.zip
I have full control of the model, but no telem is being sent back to the radio.
