[SOLVED] Can’t enable rate mode
Posted: Sun 15. Oct 2023 23:32:56
by RotoRotoR
Spirit 2 with PWM receiver (Sanwa Airtronics)
My rudder is stuck in heading hold. I have set the gyro to a three position switch on Aux 1. The switch uses +75, -50, and -100. I have the stabi function set to switch and channel 5 in the Spirit settings app.
I read that negative value should enable rate mode. What am I doing wrong?
Re: Can’t enable rate mode
Posted: Mon 16. Oct 2023 4:34:29
by RotoRotoR
Correction: I have the gyro set to channel 5. Stabi function is set to channel 7 and aux 2 for rescue normal.
Posted: Mon 16. Oct 2023 15:51:32
by Mattes61
if you don't have stabi mode enabled then a gain for example -50 is rate mode and +50 is heading hold mode -
If you use an stabi mode then only some modes have rate mode as you see here in the manual:
https://manual.spirit-system.com/index. ... #STABI_TAB
Posted: Mon 16. Oct 2023 23:58:52
by RotoRotoR
Thanks! Got it working now. I had to select stabi/function/selected by channel. This enables stabilization and rescue subtabs.
