Spirit 2 with double SRXL2 Vs Spektrum Integration
nmsantarelli
Good morning everyone on the forum,
I purchased three Spirit2 for the three helicopters and everything is ok.
I also purchased the WiFi module to make adjustments via the smart phone and everything is ok.
Yesterday I wanted to try the integration spektrum on the radio (DX6e with last update firmware) but I couldn't. In the introduction I will tell you what I have as components and how I connected them (although I did everything according to the manual).
The materials installed on the helicopter are:
- Spirit2
- Two SRXL2s, one mounted with the "Spektrum SRXL2 adapter" cable and another with the "Spektrum SRXL2 Satellite adapter" cable
- Spektrum DX6e radio
The problem is: When I select advanced programming on the radio, the radio writes "Connecting?" and after a while "Connection Error"
Did I do something wrong ?
I would be grateful for advice.
Thanks for reading, even more so if you reply to me.
Yes, you should not access integration from Advanced programming.
Please see this page:
https://manual.spirit-system.com/index. ... ntegration
nmsantarelli
ZeXx86 wrote:Yes, you should not access integration from Advanced programming.
Perfect thanks
