Spirit RS Can it support 3S Lipo (12.6v)?
shi555
Can 3s Lipo (12.6v) be used to access Spirit RS gyroscope when using external BEC?
and I am using 4 main rotor blades(800mm paddle length). Should the Cycllc phase in the expert Settings be changed (the default is 0 degrees)? If so, what value should be changed
Spirit RS is only 3,2 - 10,0 V !!
https://store.spirit-system.com/en/spir ... it-rs.html
And 4 main rotor head does not need any virtual rotation of the cyclic plate.
