Different values in PC software, WIFI link and Android app
STC...
Today on the airfield I wanted to change the governor settings of my helicopter, unfortunately I had to realize that the Ethos integretation no longer works.
So I wanted to make the settings via Bluetooth and Android app, but the setting range for Holding Performance only goes from 1 to 6, while the setting range for the PC software and WIFI link goes from 1 to 10.
What is going on?
There is only the android app showing another value (marked with the red arrow) - maybe only there is an mistake ?
thank you for your message. You are right. Android wpp has lower upper range by mistake. Because of this parameter value is not loaded there.
We will fix the issue as soon as possible.
