Tail oscillation by using rescue funktion
Voodoo2
when I use the rescue function (Acro) the tail gets an quick oscillation.
How can I change this? (Voodoo600 BLS251 Servo)
Regards Jens
linux-user
Voodoo2 wrote: when I use the rescue function (Acro) the tail gets an quick oscillation.
What is your gyro-sense?
Maybe gyro is set to high.
It also may help, if you post your settings here.
you have to configure Gyro Gain to the same value as in your conventional flight. So if you are using +60% for normal flying, for the rescue you have to set -60%.
You can also decrease little bit for the rescue.
Voodoo2
I have decreased the value and everything is fine :D
