Mixing elevator to flaps in normal mode
Yogi43
actually I'm setting up the Spirit Aero in a Freewing Avanti v2. When setting the flaps it is required to give 3mm elevator down. Is this also possible in normal mode? I assume in heading-lock mode it is not required. But how does the Spirit behave in normal mode?
The separate flaps are controlled by the receiver directly-
Yogi43
No idea? The next day with good weather conditions I just will try it out. I have defined a trim switch so that I can set the mixing on elevator to zero in case of any problems.
it should work well if the Flaps are controlled from the Receiver directly. Will work with HL or Normal mode.
Yogi43
Hi, thanks
should work means that no elevator mixing is required in HL? What about the mixing in Normal mode?
Yogi43
Are there any updates on that point?
