YGE Aureus 135 HV and RPM problem
Posted: Fri 08. Nov 2024 0:34:50
by Renzo
Hallo
All work well
but rpm do not work correctly
I have 1000RPM on the head but on display i see 15RPM
spirit Wave
spirit unit W1
what can be?
best regards Renzo
Re: YGE Aureus 135 HV and RPM problem
Posted: Tue 12. Nov 2024 19:09:43
you likely set Gear Ratio at both ESC and Spirit.
So Gear calculation is done twice times.
Please set ESC to default gear ratio, then all will be ok.
Posted: Sun 17. Nov 2024 13:01:08
by Renzo
Yes you have right
same Parameter on the ESC and on the Wave...Parameter on the ESC at standard...and the RPM is right
tank you
