Pitch pumps tail moves to the Right
TrueBuild
What setting do I need to adjust and which way?
I'm using the Spirit esc control system (not a the omp hobby esc control)
frisos@gmx.co.uk
Did you tune the tail using the tuning guide?
https://manual.spirit-system.com/index. ... ning_Guide
franz88
Set the servo bracket at 90° and after go hovering in normal mode (no avcs) and lengthen or shorten the tail tie rod until without pressing the tail stick thr noise helicopter remains still.
After check the limits again.
The tail spirit he has the best tail in the world!!!
After try to disable governor spirit and tell me if the problem goes away.
TrueBuild
Thanks guys.
I'm new to this system and still very much in the dark.
"after go hovering in normal mode (no avcs)"
For instance what is AVCS? (Found it AVCS (Angular Vector Control System ))
Is that zero Gyro?
Gyro zero = Rate mode = Normal mode ?
Gyro 50 - 100 heading hold?
Use Rate mode to set the tail before takeoff?
I've done the 3 degrees that I used to set with Microbeast systems and next I will try and disable the governor.
ExCCHP
I do believe that is what he meant.
Use Rate Mode (Gyro set to Zero) to mechanically setup the tail so the tail stays still in a static hover.
Once you have the correct amount of tail blade pitch set to hold the tail in Rate Mode in a static hover, then set Gyro to say 55. Then adjust from there so it holds in flight and during pitch pumps.
This is how I set mine. Keep in mind I am no 3D God.
So if this is incorrect, someone Please correct me.
franz88
https://manual.spirit-system.com/index. ... SENSOR_TAB
Exactly only that you have to put a correction in rate mode.
Usually
Head-Lock mode: 1% to 100%
Normal (Rate) or a special function: -100% to 0%
but this changes from radio to radio
parts with a value of -30 why if you use 0 the gyro gain it is non-existent (when you move clockwise or counterclockwise the tail servo must move and after in rate mode return to 90 degrees)
if you is head lock mode it doesn't return to 90 degrees
usually :
+50% head lock mode (0 is the value minimum and + 100 value maximum)
-30/-50 rate mode not use 0 why you will not have tail correction (0 is the value minimum and - 100 value maximum)
remove the blades and rotate the helicopter with your hands to see the movement of the tail servo and when everything is ok you go into hovering.
With 90 degree servo hovering in rate mode the nose (front) helicopter it must not rotate. (lengthen or shorten the tie rod )
Many people they give 3 or 4 degrees of inclination and stop.
go 26minutes and 46seconds use subtitle translation
https://www.youtube.com/watch?v=YM6Caw9GZh0
TrueBuild
Great thanks.
My excuse is :oops: I've been setting up Blade stuff and that has no Rate mode.
curmudgeon
I generally adjust the tail rod length so I end up with fairly equal left and right tail travels to the extremes of travel without binding during bench setup. For most helicopters, the tail blades end up with a few degrees against the main blades torque at center using this method.
When spooling up at the field, I find that if I set tail blades at about 0° pitch during spool up, there is hardly any tendency for the helicopter to rotate either CW or CCW while on the ground during spool up.
In my experience, I have not found it useful to use "rate mode" in a hover to determine tail rod length adjustment for hands-free hover. To add to this, hands-free hover using "rate mode" is head speed dependent. Meaning, if you adjust the tail rod length so you end up with hand-free hover at a certain head speed, you will find this tail rod length will NOT yield a hands-free hover at a different head speed in the same "rate mode".
franz88
every helicopter is different.
when the rotor turn clockwise, the nose of the helicopter rotate in the opposite direction.
we adjust the tie rod to tilt the tail blades (3 or 4 degrees).
Rate mode It helps you understand the degrees of inclination.
PS
first set the engine rpm and after adjust the tied rod.
then go to avcs and flights in AVCS.
but not all helicopters they behave in the same mode.
Maybe your helicopter it goes better with the degrees at 0.
all the helicopters I've tried they were fine with 3 or 4 degrees.
there is no rule for all helicopters
