Tuning - Sensor/Rotation Rate?
kcasser
In the Tuning instructions, the first section mentions "Sensor/Rotation Rate" and that it should be between 8 and 11. I can't find this parameter anywhere. I see Rotation Speed, but that is in degrees per second. What am I missing?
Sepp62
Tuning instructions are not up to date for version 4.0, where rotation rate now is in degrees/s.
kcasser
Aha! What should a normal setting be?
ExCCHP
Copied from the update log:
Configured Rotation Speed is now all in Degrees/s. Default rates are 250 °/s for Cyclic and 300 °/s for Rudder.
In my case the default was 250° & 350°.
I found the cyclic was good at 250° but the tail was too slow even at 360° so I raised it to 450°. But all personal preference. Easy enough to adjust on the fly then lock it in when you get it to your liking.
