swash plate wagging
Posted: Wed 13. Aug 2025 12:40:23
by p-51d
Hi
starting into a wide loop after taking on full speed ( collective pitch full positiv ) the swash plate seems to wagg.
There is a stall on the main blades visible and a wimmering noise hearable: The blades stall/release til
the heli is out of the loop again...
Fw 4.0.0
Spirit GTR
Spirit GeoLink v2
SAB PIUMA 700 raw
any comments wellcome
Best Regards
Re: swash plate wagging
Posted: Wed 13. Aug 2025 16:27:24
by Mattes61
Hello p-51d !
I would assume to reduce the headgain or to set the new position headdamping a little bit up -
Or swashplate Integral is to high this must be tested...
I think the heli is not dolpheneing if so then elevator filter...
Best regards
Posted: Wed 13. Aug 2025 17:05:07
by p-51d
Hi Matthes61
Thanks for your advice; I'll check and change the mentioned parameters accordingly...
What do you mean with dolpheneing ? ( moves like a dolphin ? )
Best Regards
p-51d
Posted: Wed 13. Aug 2025 18:52:34
Please share yiur settings file. I will check what could be wrong.
Posted: Wed 13. Aug 2025 20:51:22
by Mattes61
Hello p-51d !
Your setting-file would be helpful as Tomas said -
Dolphening is the tendency of Up and down as an Dolphin moves - for example you make a looping and at the end of the looping you get in the straight flight an up and down as an Dolphin swims -
Best regards
Posted: Thu 14. Aug 2025 6:37:22
by p-51d
Hi Tomas and Matthes61
as requested the setting file...
Kind Regards
13th-Aug-2025.4ds
(255 Bytes) Downloaded 182 times
