Incomplete Heli Assistant while using Jeti DS24II
JENS
I just started to use the Spirit GTR together with Jeti DS24 II. I switched from Vbar.
I did the set up via PC.
For some reason, I cannot see all settings as soon as I try it via the Jeti controller. For example I do not see the orientation of the unit on the first screen.
There is a lot missing.
As soon as I plug in the Laptop, I can find everything on the Jeti. I also can change any setting.
As soon as I unplug the Laptop, everything disappears again.
Software on both sides is 4.0.0.
What's wrong?
Thank you very much for any help!
Jens
this is very likely because you are in Bank 1 or Bank 2.
Switch Bank to 0. Then all base settings will be accessible.
JENS
This sounds absolutely reasonable!
How can I switch do Bank 0 from the controller?
Thanks again for the quick help!!
