Spirit GT with Fly Sky FS-iA10B extra channels?
helicopterjeff
I finally have my GT setup and working well. I paired it with a Fly Sky FS-iA10B 10 channel RX and a RadioMaster TX16S
The TX is setup for FlSky2A mode and PPM,SBUS protocol.
I need access to the upper 3 channels- 8, 9, 10
How do I do this?
All the channels on the RX are dead. The only port used is the bus channel.
Are these channels (not used as far as I know by the GT) usable in this config? If not, how would I accomplish this?
Thanks!
ShapeShifter
I have the exact same setup and have the same question.
ShapeShifter
helicopterjeff wrote: Sat 06. Sep 2025 23:29:37 I finally have my GT setup and working well. I paired it with a Fly Sky FS-iA10B 10 channel RX and a RadioMaster TX16S
How do I do this?
Thanks!
Look at page 33, sect 9.2 in this doc: https://www.horizonhobby.com/on/demandw ... aign=41227
It talks about how to configure the FS-iA10B Rx for PPM through menus on the Flysky transmitter, however, it implies that when PPM output signal is active, all other channel outputs are disabled. This my be our answer (unfortunately). Spirit support team may have more info, but the FS-iA10B may not be the way to go if more channels are needed.
helicopterjeff
Thanks for finding that- it doesn't apply- I don't have that TX. I tried PPM and a few others and it didn't make a difference with the RadioMaster TX16. I had hoped it would.
I did found out that the aux1 on the GT can be mapped to a TX channel. (7 in this case). This will work for now.
you will need to use SBUS protocol. This can carry all channels. Then the extra channels will work out of the box.
