Governor issues with 4.0 firmware
Khedge
Hello all.
Whiplash turbine heli. Xicoy x45h. Jeti ds-24ii and spirit gtr.
i updated to the 4.0 firmware on my whiplash turbine and all is well except the governor is not responding properly. I did a re learn on my turbines which is a xicoy x45h. The issue is the when i switch to bank 1 and 2 the turbine will accelerate to the headspeed but then the turbine rpm drop. I have tried increasing the throttle curve for the banks and that doesnt work. Is there something am messing in the governor settings?
V/r
Karl
Can you attach settings for each of your bank? I will check it. Bank files are enough.
Khedge
Sure i will upload them
Khedge
Tomas, attached are the banks as requested.
whiplash_bank2.4ds
Governor enabled_HS1900
(255 Bytes) Downloaded 294 times
whiplash_bank1.4ds
Governor enabled_HS1750
(255 Bytes) Downloaded 296 times
whiplash_bank0.4ds
Bank0_ Governor disabled
(255 Bytes) Downloaded 303 times
Khedge
Tomas were you able to review my bank files. I am still having the same issue. I am just going to setup my model again from the beginning. I have looked at everything and also did a relearn on the turbine a few times. The issue is intermitted. I tried to fly today and the governor does the same. I my hover bank it will hold the headspeed. Then when i flip to bank 1 and 2 the turbine will accelerate and the slowly decrease the rpm and the headspeed lowers as well. My governor settings are governor performance 4, hold performance 3, and hold limit is 65. Any thoughts?
