[ Version 4.0.2 released! ]
New version 4.0.2 released!
Fine-Tuning update with a major tweaks for all Spirit units is available now!
Changes are following:
  • Swashplate Stopping:
    • Together with the best pilots we implemented solution for even better stopping performance.
    • New algorithm has aim to achieve butter smooth and fast stopping from a very high rotation rates.
    • Parameter is accessible in the Expert Settings, called Swashplate - Stop Smoothing. It has range from 0 - 9.
    • Value 0 has algorithm disabled making stopping identical to previous firmware.
    • Value from 1 will achieve crisper and more precise stopping without overshoot.
    • High value will result in too smooth stopping.
    • Recommended to tune after Elevator Filter parameter.
    • Perfect for pilots that want to obtain maximum out of the model while maintaining high Gain, Swashplate Integral, Feed Forward and aggressive rotor blades.
    • It makes initial tuning easier, because it is enabled by default (value 1).
  • Spirit Settings software:
    • Expert window was reworked to make it cleaner, dividing parameters into a dedicated tabs according their purpose.
    • Parameter descriptions were extended in a tool tips of the software.
  • Scorpion ESC Integration:
    • Added support for Scorpion Tribunus III.
    • Fixed ESC telemetry not showing when using Wave radio (with firmware 4.0.1).
  • ELRS/CRSF Integration:
    • Fixed configuration of Elevator Filter.
    • Fixed configuration of Rudder Common Gain.
  • Spirit RX protocol:
    • Corrupted RX frame right after initialization will be not displayed anymore in the Event Log.
    • Fixed Main Loop Hang when exiting special configuration modes when using Spirit Pro.
  • Swashplate Dampening parameter:
    • Parameter is entirely disabled when configuring to 0.
    • This could help for a Fast Forward Flight.
  • New 3D Master Mode:
    • Mode tailored for 3D Master pilots for tuning Spirit to the biggest detail.
    • No more compromises.
    • More details to be revealed in the following days!
Update for the Spirit units is available in our Download section.
NOTE: New parameter Swashplate - Stop Smoothing is configured to 1 after update from previous versions.
Big thanks to Timo Wendtland and all other Team and Test pilots for extensive support and testing!
