[SOLVED] 3d Master Mode issue
IFHELI
I have two Spirit GT and two Spirit II. The 3D master mode will only stay checked on one Spirit GT in all three banks. On the other three units it will only stay check in Bank 0. What am I missing here?
Please try to redownload the PC software. It should be available only in Bank 0 and will affect all. If it is enabled, it will be enabled for all Banks.
IFHELI
The redownload of the PC software worked on the Spirit GT. It not work for the two Spirit II.
the problem could be that in your Bank 1 and 2 there is way too old settings saved that is not compatible with the latest one. For example from version 4.0.1. Since then there was no change in these banks and this will block new 3DMaster mode.
It is enough to save the settings in Bank 1 and Bank 2 and all should be OK.
IFHELI
Thank you,
That was it. I never thought to try a reset to factory settings. I did that on one Spirit II and made a few changes on settings on another one. That solved all the issue I`m having except a minor connection issue. It will still fail to connect using Windows 11 once in a while.
There is never need to factory reset, because Spirit will show always what is configured (no hidden settings). The only issue was that your settings for Bank 1/Bank 2 were out of dated, saved months ago when many parameters were different and there was no 3DMaster mode.
IFHELI
I only did the factory reset because that Spirit II was not in a heli at the moment. If I had tried that before making my post I may have found it was outdated settings causing my problem.
