Specifies Gyro Gain Rudder Gain :- is Grayed out - Inactive if Gyro Gain is configured in the transmitter (Update)
TrueBuild
UPDATE:_
Note:- I'm using the Wifi link 4.0.3
Realizing part of problem is setting up the Spektrum Transmitter. So I asked on a Spektrum forum how to make the same switch as the Bank switch change the Gyro channel 5 in my transmitter.
I got Gyro channel to change values from 70,60 and 50 to match each change of bank 0, 1 and 2
Bank 0 Gyro 70
Bank 1 Gyro 60
Bank 2 Gyro 50
But the value of Gyro Rudder Gain still does not change :(
End Of UPDATE.
I'm using Banks 1,2 and 3 I would like Rudder Gain to be in the Banks so it can be head speed specific; if that makes sense?
How do I remove the configured Gyro Gain in the transmitter that is currently on a three position switch (not my Bank switch)?
I did it that way because I wanted a rate mode to check if tail was set correctly.
Is the correct way to go to the channels menu and set Channel 5 that currently controls Gyro gain to Unassigned?
Spektrum transmitter.
Helicopter is a standard build OMP M4 Max.
you have to look at the Diagnostic page for checking what is your Gyro Gain. This mean that your current setup is probably working correctly.
If you want to set Gyro Gain permanently in the unit, then you need to unassign Channel 5 and Gyro Gain settings will become available in the Sensor tab.
