[ Spirit Aero 1.9.0 released! ]
Posted: Thu 09. Jul 2026 12:26:54
Version 1.9.0 - ChangeLog:
It brings many new features and improvements:
- Spirit W3 support:
- Added support for Spirit W3 units.
- YGE ESC Setup support:
- Compatibility with the latest YGE ESC firmware was fixed.
- The ESC will work out of the box with full Telemetry and Integration support when using Spirit Wave radio.
- New Scorpion ESC Setup support:
- From now all Scorpion Tribunus ESC can be directly configured through Spirit Wave radio.
- Wiring require no change from Scorpion ESC guide. Only Telem UNI cable is required to make it work.
- Make sure that Spirit Wave is updated to the latest 1.0.25+ firmware.
- Scorpion ESC telemetry:
- Added support for Scorpion Tribunus III.
- Setpoint and PWM telemetry variables are available for Spirit Wave.
- ESC telemetry - Kontronik TelMe:
- Added new data checking for all telemetry frames.
- This will avoid displaying and logging incorrect values.
- New ESC telemetry - FlyRotor:
- All FlyRotor ESCs are fully supported and can display ESC telemetry.
- All Spirit units except v1 have this support.
- Wiring can be done through Telem UNI cable at the SAT1 port.
- ELRS/CRSF telemetry:
- New telemetry variables that carry RPM and Temperature natively.
- Spirit Aero PC software:
- User Interface was reworked to improve navigation through the menus.
- Menu Tabs were relocated to a Side panel.
- Minimize and Maximize window buttons are displayed on Windows and OSX now.
- Spirit Aero Theme:
- You can configure App Theme in the Configuration - Appearance window.
- Available themes are:
- Default
- Dark Yellow
- Dark Red
- Dark Blue
- Cocoa
- Mac OSX will use theme Cocoa by default.
NOTE: No need to reconfigure any parameter after updating from 1.8.1.
