Help with step adjustment on different banks
Posted: Tue 22. Sep 2026 20:10:44
by mascio
Good evening. Can anyone tell me why, with the stick at 100% in Normal mode and Bank 2, I get 11 degrees of pitch, yet in Bank 1 it barely reaches 8.5 degrees—even though both the stick and software settings are at 100%? I'm using a Radio Wave setup with a Spirit W1. Thanks in advance to anyone who can help.
Re: Help with step adjustment on different banks
Posted: Tue 22. Sep 2026 20:27:02
by delta peak
When you go to Limits tab, is the value of collective pitch the same for all banks?
Posted: Wed 23. Sep 2026 7:33:10
by mascio
Yes, it's the same for all three... It's a very strange thing. Thanks for the help, by the way.
Posted: Wed 23. Sep 2026 7:34:35
Please share your settings files for all banks, then I can tell you exactly what is wrong.
Posted: Wed 23. Sep 2026 22:58:29
by mascio
Grazie mille per la pazienza penso di aver risolto ma ora mi manca la configurazione del rescue automatic . Puoi controllarmi gentilmente iei file l' attivazione del rescue automatic ? Utilizzo RU ma mi dice che e attivato ma sull lcd non esce scritto impegnato ma se cambio interruttore funziona ma non capisco se veramente funziona perchè il piatto ciclico va su e giu a distanza di circa 3/4 secondi.. Grazie mille
