DX8 Rescue
maddog1963
Hi
I want to set the rescue mode to the gear switch on my DX8.
I can assign aux 2 to the switch in system setup/ switch select but very unsure what to set up in the function/monitor or mixing to make it work correctly? Or am I completely wrong in what I am proposing?
Any help please
djhandz
Dx8 has a error when in switch select on dx8 mix is the gear switch. No mixing required
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
maddog1963
Thank you, all works now , set a -70 in stabi for normal rescue and when I activate the gear switch I get a maximum 10 degree of positive pitch which should be OK for my sport flying.
Just need to maiden now with the spirit on board.
