Tail ESC possible?
Posted: Mon 15. Jun 2015 19:30:51
by ajadda
I wonder if it was possible to use a tail ESC instead of a tail servo.
If so, what should I take care of?
Regards,
Alexander
Re: Tail ESC possible?
Posted: Mon 15. Jun 2015 21:19:29
What do you mean by Tail ESC?
Do you want to connect ESC to the CH4 port? What is the reason for this?
Posted: Mon 15. Jun 2015 22:04:50
by ajadda
Yes, that is what I was thinking about.
I have a small heli with a tail-motor driven by a separate ESC.
Posted: Mon 15. Jun 2015 22:33:02
Yes, it is possible. But the tuning will be little bit different than with normal servo.
Posted: Mon 15. Jun 2015 22:45:09
by ajadda
Thank you for the information!
I am sure there will be differences compared to a servo, a motor is much slower in any reaction, there are not really rudder endpoints...
Should I use slowest frequency for the ESC?
Posted: Mon 15. Jun 2015 22:56:56
60 Hz should be fine.
You can use rudder endpoints to set throttle range for the ESC.
