[SOLVED] BT and v 1.2.1 ?
Posted: Fri 31. Jul 2015 7:57:34
by Dawiev
Hi, I upgraded the firmware to 1.2.1 and now the BT module doesn't connect.
Before I revert back to 1.2.0, is there something I need to do to make it work in a new release ?
Re: BT and v 1.2.1 ?
Posted: Fri 31. Jul 2015 8:49:23
by error414
android app should be work without trouble with 1.2.1 version.
What does it mean "doesn't connect"?
Posted: Fri 31. Jul 2015 13:53:08
by Dawiev
Thanks for the reply.
Device is paired. On the connection screen it connects but the serial and firmware fields stay "unknown". When I move to the next screen it pops up a "reading data" and then posts a connection error and stops,
Posted: Fri 31. Jul 2015 15:58:01
Most probably your BT module is not connected properly to the SYS port or you are powering the module from external battery, not same as the unit.
Posted: Fri 31. Jul 2015 16:18:40
by Dawiev
Oops !! Where's the smiley with the red face ?
Powered it from a different battery. All's good now.
