1.3.0 firmware file
Coco66
File is .4df instead of .bin, roughly 120KB instead of around 50KB, and no published checksum... sure?
MyRCode
I just flashed it... Going to the field right now. I'll let you know in
about 20 minutes
Sent from my XT1254 using Tapatalk
Please check our release notes, you can find more details about the new firmware format here.
MyRCode
It flies! Don't forget to re-enable your governor after the update.... And download the new software on your phone if you're using it
Malc1
Just wondering, did you unplug all the cables from the unit before carrying out the update?
MyRCode
Malc1 wrote:Just wondering, did you unplug all the cables from the unit before carrying out the update?
Nope... Just plugged in the USB cable
Malc1
OK I have downloaded the file but am unable to update the unit as the firmware update software is only looking for a .bin file.
There is no option to search for any other type.
Windows XP. Any ideas?
You have to download and install also the new software.
Old software does not support new firmware format.
Malc1
OK will try this now.
Malc1
Updated successfully and Nitro governor set up again.
On the bench the first thing I've noticed is that the throttle servo still goes over to full throttle but it no longer pulses continuously when it gets there.
I'm using a Jeti DS16,do I need to update a file for this to work correctly?
