spirit 1.3 gov setting
Posted: Thu 01. Oct 2015 22:48:34
by walle999
Hi there i wonder what the refresh rate should be on castle edge series speed controllers it say on there home page "ESC now supports, and USES, high frequency receiver pulses (100+ hz). In previous versions of firmware, receiver input was processed at 50hz." from version 4.0 and higher, but what value should i use in spirit gov. can a to high value damage or make any illeffects if its not supported by the esc?
Best regards
Niclas
Re: spirit 1.3 gov setting
Posted: Fri 02. Oct 2015 7:25:53
ESC shouldn't be damaged, but some problems may occur.
Mostly it is strange spoolup behavior if there is any used by the ESC.
I recommend to not use higher frequency than 200Hz for any ESC and examine if it is not too hot.
