servos go crazy when saving banks
djhandz
Setting up spirit pro software/firmware 1.3.1 when making changes and saving banks the servos go crazy and i have to disconnect power any ideas scared of damaging my servos
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
could you tell me, what is your receiver type and if it happen when you turn off the receiver?
djhandz
I am using 2 dsmx sats wired direct to unit with a dx9
Great, then can you try if the problem is there when you start the unit without transmitter?
djhandz
I will test without tx after work. Thanks. Thinking ahead without the tx on its not possible to set limits/pitch range would a work around be to setup with tx on set limits but then before i go to save the settings turn off the tx??
Coco66
I think they want to see if the servos behave like that when not "bound". Maybe that's what happens while you are saving banks, some re-initialization happens that "suspends" the bind. Just speculating ))))))
elfew
I can confirm that. I got this in 1.2 too, but I dont know how to reproduce it. Same configuration 2x dsmx sats.
Servos just go crazy
DX9 - Chase 360 - Spirit
djhandz
Tested with tx off and no issues.. but how do i set limits and pitch with tx off ??
You can use your TX without any problem all the time.
Does the issue happen each time?
djhandz
Yes each time i go to save when the tx is on they go crazy
