Governor With Jeti Mezon
Rcpassa
Hey everybody,
I hope somebody may know the answer to this. I have a Jeti mezon 130 in my 3 bladed Goblin 570 and i use the spirit pro governor. i have FW version 2.0.2 (because I'm using a rex7 receiver). when i spool it up, it will get to roughly 1600-1800 then slow down roughly 200 rpm. it will then start to climb up to normal RPM. This process causes my spool up time to be roughly 35-45 seconds...;any idea what may be going on?
Thank you!
James
velocity90
Search for the mezon external gov guide by hacker and use those settings, but you will never get good performance. Mezon has a lot of delay so unusable for external gov
-TT E700 V2-Spirit Pro-mks950-980-Kontronik Kosmik 160 HV -Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+ Spirit Pro
Rcpassa
Where can i find this guide? I've searched everywhere...
sacha
Here is it.
Sacha
Master MEZON VBar Gov.mode D-E.pdf
(1.44 MiB) Downloaded 174 times
