Hey everybody,
I hope somebody may know the answer to this. I have a Jeti mezon 130 in my 3 bladed Goblin 570 and i use the spirit pro governor. i have FW version 2.0.2 (because I'm using a rex7 receiver). when i spool it up, it will get to roughly 1600-1800 then slow down roughly 200 rpm. it will then start to climb up to normal RPM. This process causes my spool up time to be roughly 35-45 seconds...;any idea what may be going on?
Thank you!
James
Governor With Jeti Mezon
velocity90
Search for the mezon external gov guide by hacker and use those settings, but you will never get good performance. Mezon has a lot of delay so unusable for external gov
Here is it.
Sacha
Sacha
- Attachments
- Master MEZON VBar Gov.mode D-E.pdf
- (1.44 MiB) Downloaded 206 times
