GYRO NORMAL RATE+STABY
delfo
Hi, I use two banks:
In the first I do not have the staby and the gyro (adjustable by tx with knob) has the HL-0-Normal function.
In the second I have staby, but the gyro only has HL-0-HL + Staby functions.
Is it possible in bank 2 to have the HL-0-Normal + Staby function? I not want HL with Staby.[emoji6]
delfo
Hi, same replay?
sorry for late reply.
You can configure it in this way:
Bank 0:
Stabi/Function - Disabled
Bank 2:
Stabi/Function - Stabilisation (Normal or Acro)
For both Banks set Global Gain to a negative value.
Then there will be only Normal mode or Stabilisation. With Bank switch you can change it anytime.
delfo
Thanks, I try :)
delfo
Hi I set general gain with negative value for both banks, but the situation is non changed, see screenshot.
In this situation I need the Normal+Staby not Head-look+Staby.
Is possible? Thanks
Ah, this is not possible. Otherwise stabilisation mode will not work. It would not hold required attitude.
So then Stabilisation mode will have no meaning in this case.
delfo
Ok, many thanks.
You are welcome.
But you can still enable Normal mode (without active Stabilisation). This will make a different behavior.
