Hello!
I use the spirit telemetry with a DS16. I connected the Spirit with the Telem Uni Cable with my Hobbywing 160.
But I do not get any data?
The problem is, I had previously connected a Hobbywing 130, because it worked!
Where could be the source of the error?
Frank
[SOLVED] Hobbywing 160 with Telemetrie UNI Cable... No Data?
your ESC is probably not updated.
Older firmware version does not support telemetry feature.
According HobbyWing web page you need PL-04.0.06.
http://www.hobbywing.com/Upload/softwar ... icalTab_37
Are you sure you are connecting it in the correct Spektrum port?
Is the HobbyWing telemetry still enabled in the settings?
I guess the cable must be good if it worked with your other ESC.
Also we are testing each prior the shipping.
Very well.
Thank you for your message!
