[SOLVED] Hobbywing 160 with Telemetrie UNI Cable... No Data?
Franky13
Hello!
I use the spirit telemetry with a DS16. I connected the Spirit with the Telem Uni Cable with my Hobbywing 160.
But I do not get any data?
The problem is, I had previously connected a Hobbywing 130, because it worked!
Where could be the source of the error?
Frank
your ESC is probably not updated.
Older firmware version does not support telemetry feature.
Franky13
Ok, it will update this evening!
Franky13
Update is on it.
Version 4.0.4 (Hobbywing) from 12.08.2017
Nevertheless, no data, only the temperature is displayed ...
The other values are zero.
Greeting
According HobbyWing web page you need PL-04.0.06.
http://www.hobbywing.com/Upload/softwar ... icalTab_37
Franky13
Hi Tomas!
Even with the 4.0.06 i get no data.
Telem UNI Cable defekt?
Are you sure you are connecting it in the correct Spektrum port?
Is the HobbyWing telemetry still enabled in the settings?
I guess the cable must be good if it worked with your other ESC.
Also we are testing each prior the shipping.
Franky13
I will rebuild the cable again in my TDF.
There it worked with the HW 130 yes in the TDF!
I will test tomorrow.
Franky13
Hello Tomas!
When building back I found a broken cable.
Do not ask me how that could be done :?:
Repaired, now it works fine again!
Greeting Frank
Very well.
Thank you for your message!
