troubles reset module on Trex 700 nitro
Good. Could you try to change Frame rate? Default should be 17ms.
Can you verify what is current settings? It can be configured in your receiver (Device Explorer).
passe partout
OK there is "auto" and the frequency has been changed to 100Hz for more smooth movement.
passe partout
Hello, I searched everywhere I do not see where to come from. ???
100Hz settings is good.
Please verify how Output period is configured in your receiver.
Default is 17ms. How it is configured in your receiver?
Changing the value could help.
Could you also show me how General/Channels is configured please?
You can attach you 4ds file or take a screenshot.
passe partout
Hello, here are the files in PJ
Cdlt
2 sur 700 thermique.4ds
(255 Bytes) Downloaded 121 times
1 sur 700 thermique.4ds
(255 Bytes) Downloaded 115 times
0 sur 700 thermique.4ds
(255 Bytes) Downloaded 118 times
passe partout
passe partout
There is still a problem, the helicopter is flying, but I have to start several times before it works well.
Please try to flash the latest firmware 2.6.4 first.
Also could you verify the Spirit Flight log?
Please open the log and check the first line. Do you see "Backup oscillator is used"?
passe partout
The problem is still present, all versions are up to date. I despair.
Thank you for the message.
Could you please try the last thing - disconnect absolutely everything that is not necessary, except 3 cyclic servos and power supply.
You can even disconnect receiver.
Will this problem happen again?
