troubles reset module on Trex 700 nitro
passe partout
Hello Thomas, happy end of year celebrations.
It is difficult the breakdown is random.
I tried many times as you ask, leaving the 3 main plugged in, apparently the fault is gone.
By plugging everything in, it happens 1 time in 10 that the fault appears.
On the displays when there is a breakdown, the aileron servo is problematic, see screen photos.
I flew like that no worries once properly initialized.
Thank you for your participation.
Cdlt
spirit-log-2019-12-28-110119.pdf
(73.01 KiB) Downloaded 107 times
passe partout
Hello, it still does not work, I leave like this and I fly, if the reset is not done well at the start, I stop and I start again.
passe partout
Hello, yesterday day with no wind, beautiful sun, the 700 left on the side in rapid flight before, impossible to catch it, it fell very hard, by by 700 completely hs.
Why ?????
this is very sad. Unfortunately I dont understand why the problem is happening, it does not happen to anybody else.
Do you have flight log to check what happened?
passe partout
Hello, with the new version 3.1.0 this problem has disappeared, it has never prevented me from flying but often I had to redo the module startup several times.
Merci et bon WE.
thank you for the message.
That is very interesting, because we dont know about any change that could help with this, but it is great!
passe partout
Hello Tomas, sorry for the false good news, I flew yesterday and it still looks the same, nothing has changed, I don't really see what it can be. I had other problems after the update, in flight the plateau goes down alone for 1/10 of a second from time to time, not at a standstill.
thestructured
Have you tried a different receiver?
passe partout
No it worked fine before update, I didn't change any component.
thestructured
I think since the problem the entire duration of this thread was with the same receiver, it may be worth trying a different one to see if the problem goes away, along with new wiring. At least then you can rule those components out.
