Just asking this in here, probably not a Spirit issue at all, just checking? Maybe related to OpenTX v2.3.5, on a Taranis X9D+ with a Hobbywing 200A ESC and Spirit Pro. Suddenly I see random very high numbers in Telemetry, such as for ESC Temp max and RPM min (looks like Int32 Max to me).
Any suggestions where to look?
Cheers!
Very high values in OpenTX Telemetry
are you able to downgrade OpenTX firmware and compare the results?
I have these also - but in my case for Fuel +, which I was using to see maximum vibes
This is with OpenTx 2.3.5, the latest V2.0.1 ACCST firmware using micro Spirit with HW integration and OpenTx integration (2.7.1 version). I foolishly changed the ACCST firmware, Changed the OpenTx firmware and added Fuel+ to my telemetry screen all on the same day so I don't know which one introduced the problem
Yep, that's what I am seeing exactly, I will go back to v1 ACCST D16 firmware I think.Mikej wrote:I have these also - but in my case for Fuel +, which I was using to see maximum vibes
No worriesMikej wrote:Thanks for updating on this - I've only seen it on Fuel+, but I also get a lot of "Sensor Lost" warnings with the V2.0.1, and Fuel+ will keep the weird value as it is a maximum field whereas the other sensors will get overwritten.
ferdey wrote:No worriesMikej wrote:Thanks for updating on this - I've only seen it on Fuel+, but I also get a lot of "Sensor Lost" warnings with the V2.0.1, and Fuel+ will keep the weird value as it is a maximum field whereas the other sensors will get overwritten.I was midly worried when I got an ESC Temp warning 12 seconds into a flight and I glanced down and saw the ESC temp was around 62 million degrees C lol
