... and is Spektrum Programmer App logged into your Spektrum account? (left, upper) there should be written "Logged in as" & your Spektrum account (first) name...
Well done, As you found out it needs to plug into data port and will work with the spirit through this port. But if you use a 4651T as a sat with the 6610T you will need to use port 1 to the spirit....
10x wrote:If it see's a srxl2 signal within the first 500Ms it reverts to SRXL2..
Small correction: if a device wants to communicate via SRXL2 on the throttle port, it must answer within 200 milli seconds.
If a SRXL2 receiver does not get the handshake within that period, it will revert to "normal" PWM mode, see Specification for Spektrum® SRXL2.
@10x... as you are 'playing around' a lot with srxl2 too... did you test failsafe? how is your experience? as i my parallel thread... i am in trouble with it not working
