Spirit GT Presure Sensor issue's
Dr.Fleming
Yesterday Test flight, to see how it works the minimum altitude programmed with the Spirit GT presure sensor,
the Heli still goes direction to the ground , after passing the minimum programmed 10 meters.
On the PC I see "Activated" when I select the on function on the transmitter.
Loetefix
Please post a backup from your settings and a Picture of your Spirit Unit on the Helicopter.
Dr.Fleming
Loetefix wrote:Please post a backup from your settings and a Picture of your Spirit Unit on the Helicopter.
Thank's for the quick reply, here a Picture of my Heli's and a Youtube Link with one of the first Test Flight with my Kraken, also I have to say again , I like the Factory setup just out of the Box, will Try to fine tune this weekend but I think not much to do.
Of the other side my Goblin 500 GeoLink Test Rabbit not like to do the GeoLink functions, even I see on the Software it works showing "ACTIVE".
And my other Goblin 500 Red white Test Rabbit not like to do the basic GT's functions , like the altitude limit.
Even I see on the Software it works showing "ACTIVE".
Also the Kraken Test Rabbit I like it .
As you see on the picture I do not have a problem with Channel's quantity and Functions, ( from Transmitter side)
https://www.youtube.com/watch?v=PSlDV4L4mC0
By the way it was strong wind , you can hear it in the video.
Loetefix
And where is the Backup file (*.4ds) ?
Dr.Fleming
Loetefix wrote:And where is the Backup file (*.4ds) ?
Thank's a lot for the quick reply, here all backup's from all Bank's.
Goblin 500 no GeoLink test altitude limit 06072021.4ds
(255 Bytes) Downloaded 84 times
Goblin 500 no GeoLink test altitude limit 3 06072021.4ds
(255 Bytes) Downloaded 77 times
Goblin 500 no GeoLink test altitude limit 2 06072021.4ds
(255 Bytes) Downloaded 72 times
Loetefix
Only limit3 is configured as Automatic rescue. Did you use that Bank while testing with activated Rescue switch?
Dr.Fleming
Loetefix wrote:Only limit3 is configured as Automatic rescue. Did you use that Bank while testing with activated Rescue switch?
Yes I use Bank 0, 1, 2. Also as I mention I see on the Sofware that the Functions selected by the Transmitter,
it changes to "Activate" I double check it on the Transmitter Servo Windows and the selected channel are working, I select on the Transmitter a spring back switch that I selected for Rescue normal, but I see on the software ,
example when the Minimum altitude is selected, that the normal rescue selected with the other switch doesn`work too.
But like I write before , even the minimum altitude is not working, as I read it must stop at the minimum altitude pre-programmed and gave the Heli par example 60% Pitch to continue the rescue. But nothing happen.
Loetefix
I am not sure. But i think you have to switch on the rescue with a normal switch in the bank where the automatic rescue is activated.Not momentary. So you chose the auto rescue bank and switch the rescue on (in your case channel 8)with a normal switch while flying(not momentary).
Gesendet von meinem Mi 9 Lite mit Tapatalk
Dr.Fleming
Loetefix wrote:I am not sure. But i think you have to switch on the rescue with a normal switch in the bank where the automatic rescue is activated.Not momentary. So you chose the auto rescue bank and switch the rescue on (in your case channel 8)with a normal switch while flying(not momentary).
Hi sorry I not explain very well my english writing is not of the best, I have the function rescue normal on the momentary switch.
And the minimum altitude ( automatic rescue by goin more down to the ground on pregrommaed 10 meters) is on a 3 way switch.
Loetefix
German?
