Yesterday Test flight, to see how it works the minimum altitude programmed with the Spirit GT presure sensor,
the Heli still goes direction to the ground , after passing the minimum programmed 10 meters.
On the PC I see "Activated" when I select the on function on the transmitter.
Spirit GT Presure Sensor issue's
Dr.Fleming
Thank's for the quick reply, here a Picture of my Heli's and a Youtube Link with one of the first Test Flight with my Kraken, also I have to say again , I like the Factory setup just out of the Box, will Try to fine tune this weekend but I think not much to do.Loetefix wrote:Please post a backup from your settings and a Picture of your Spirit Unit on the Helicopter.
Of the other side my Goblin 500 GeoLink Test Rabbit not like to do the GeoLink functions, even I see on the Software it works showing "ACTIVE".
And my other Goblin 500 Red white Test Rabbit not like to do the basic GT's functions , like the altitude limit.
Even I see on the Software it works showing "ACTIVE".
Also the Kraken Test Rabbit I like it .
As you see on the picture I do not have a problem with Channel's quantity and Functions, ( from Transmitter side)
https://www.youtube.com/watch?v=PSlDV4L4mC0
By the way it was strong wind , you can hear it in the video.
Dr.Fleming
Thank's a lot for the quick reply, here all backup's from all Bank's.Loetefix wrote:And where is the Backup file (*.4ds) ?
- Attachments
- Goblin 500 no GeoLink test altitude limit 06072021.4ds
- (255 Bytes) Downloaded 91 times
- Goblin 500 no GeoLink test altitude limit 3 06072021.4ds
- (255 Bytes) Downloaded 84 times
- Goblin 500 no GeoLink test altitude limit 2 06072021.4ds
- (255 Bytes) Downloaded 79 times
Dr.Fleming
Yes I use Bank 0, 1, 2. Also as I mention I see on the Sofware that the Functions selected by the Transmitter,Loetefix wrote:Only limit3 is configured as Automatic rescue. Did you use that Bank while testing with activated Rescue switch?
it changes to "Activate" I double check it on the Transmitter Servo Windows and the selected channel are working, I select on the Transmitter a spring back switch that I selected for Rescue normal, but I see on the software ,
example when the Minimum altitude is selected, that the normal rescue selected with the other switch doesn`work too.
But like I write before , even the minimum altitude is not working, as I read it must stop at the minimum altitude pre-programmed and gave the Heli par example 60% Pitch to continue the rescue. But nothing happen.
I am not sure. But i think you have to switch on the rescue with a normal switch in the bank where the automatic rescue is activated.Not momentary. So you chose the auto rescue bank and switch the rescue on (in your case channel 8)with a normal switch while flying(not momentary).
Gesendet von meinem Mi 9 Lite mit Tapatalk
Dr.Fleming
Hi sorry I not explain very well my english writing is not of the best, I have the function rescue normal on the momentary switch.Loetefix wrote:I am not sure. But i think you have to switch on the rescue with a normal switch in the bank where the automatic rescue is activated.Not momentary. So you chose the auto rescue bank and switch the rescue on (in your case channel 8)with a normal switch while flying(not momentary).
And the minimum altitude ( automatic rescue by goin more down to the ground on pregrommaed 10 meters) is on a 3 way switch.
