Can I use FrSky's Inverted F.Port port?
xoexoe
I already wired up my Archer RS to use the Inverted S.Bus/F.Port port with Brain2/Ikon2. Now I want to use the same receiver to try out the Spirit GT. Do I need to resolder to the S.Bus port?
Screen Shot 2021-08-05 at 8.16.31 PM.png (29.49 KiB) Viewed 2352 times
Find me on HeliFreak, username Xoexoe
Ahmad.Kassem
Resolder the wire to the third pin (sbus) and flash fport FW and you are good to go
Sent from my SM-N976Q using Tapatalk
Ahmad.Kassem
Sorry sport
xoexoe
I want to use F.Port. And I believe there’s no flashing required Archer RS because you can switch protocols from the TX via ACCESS
you will need normal/stock wiring of the receiver.
xoexoe
Thank you.
