[SOLVED] Issues with GeoLink, sometimes Functions work
Everything is automatic. You will only change switch position when flying and it will move the model to lift off position.
Dr.Fleming
Hello, something is not matching, I try to adjust now with Dualrate, but no luck, on WIndows channelZeXx86 wrote:Everything is automatic. You will only change switch position when flying and it will move the model to lift off position.
mapping shows 3, but on the GeoLink Aid Tab show : Programing all Banks.?
Why it's so difficult.
It is not difficult at all. Changing channel value takes only few seconds.
You have to only change channel value to be between 27% - 56%.
Dr.Fleming
Hi thanks for the quick response , I try everything with endpoints now with dualrates,ZeXx86 wrote:It is not difficult at all. Changing channel value takes only few seconds.
with this values, Futaba Transmittrer stays at Number3, can you please catch a Futaba Transmitter,
and send me the endpoint and dualrate setup, thanks.
This is because your channel has to be reversed. On (3) is visible from -61% - -38%. So it is enough to use channel reverse and then it will work.
Dr.Fleming
Hi, I try already with reverse, but not the combination endpoint wit dualrate, will try now, thanks.ZeXx86 wrote:This is because your channel has to be reversed. On (3) is visible from -61% - -38%. So it is enough to use channel reverse and then it will work.
Dr.Fleming
Hi, also with the channel reverse, and the Limit and travel to 38% it shows (4) = Active ( Return to Home - Power Up spot)ZeXx86 wrote:This is because your channel has to be reversed. On (3) is visible from -61% - -38%. So it is enough to use channel reverse and then it will work.
And on the other side value 61% on Travel and Limit shows (3) Active ( Programing - all Banks)
But the problem is I cannot switch to the Function Return to Home.
You know that Futaba Transmitters you can adjust the Limit and the Travel of each channel.
Dr.Fleming
Hello, I think it is much easier and safer to take out the GeoLink Funtion Altitude Limit from the window channel mapping,ZeXx86 wrote:This is because your channel has to be reversed. On (3) is visible from -61% - -38%. So it is enough to use channel reverse and then it will work.
and re-emplace for this the Function 6.2.4 On (4) Channel value 27% - 56% : When On (4).
Because this Function is much more important, bey the minimum mistake
the Heli will Flight away. And by the way I lose another week trying to adjust with endpoints Dualrates and reverse, but not works.
