AR6610T + 4651T Receiver not work
Johannes Fölsing
Hello, everyone,
I'm trying to get the AR6610T + 4651T to work. But it doesn't work. Both receivers have the latest firmware. I have connected the AR6610T to channel 1 according to various forums and the 4651T to the SRXL2 connector on the AR6610T. The heli does not initialize. It only works when I connect the AR6610T alone. Then via the Bind/DAt/SRXL2 port. What do I have to do to initialize the heli when the FBL is connected to channel 1 of the AR6610T? Many thanks for your help
10x
When i was using Spektrum i had the same receivers wired the same as you and it all worked ok...I had to use pins 1 when i was using the 4651t
How did you bind the receivers?...I connected together the 4651 and 6610 and pushed the bind button on the 4651 to start both receivers flashing....
Johannes Fölsing
I pressed the button on the AR6610T. then both receivers flashed and I was able to bind successfully. nevertheless the heli does not initialize. I'll test again if it makes a difference when I press the button on the 4651T.
Johannes Fölsing
I pushed now in 4651T.
Nothing works :(
in the FBL, the SRXL2 output is correct, isn't it? so even if it is connected to channel 1?
Hello Johannes,
I have tested the same configuration as you and it works for me - what firmware have you installed on spitit II ? Install the newest 3.33 one - Can you try it with the original cable for satellite receiver ? My binding procedure is as follows push both binding buttons at the same time an then push in the supply voltage, you don't need spirit at this moment because binding is only a part of spektrum radio and receiver - in this way it woks for me -
Some thing I have forgotten to say, have you the latest firmware in your radio too ? Also you have to look at the newest firmware of the satellite receiver by registering on spektrum homepage, then it must work !
Best regards
Matthias
Johannes Fölsing
Hello, thank you for your support.
I have the latest firmware installed on the transmitter and both receivers. All products are registered with Spektrum. I soldered the original cable. The receivers both go into bind mode and it binds successfully. But the heli doesn't respond. I noticed that the 4651T flashes earlier than the AR6610T. If that means anything? AR6610T only works on the BIND/DAT/SRXL2 port when I connect it alone. Binding works without problems on port 1, but the FBL does not recognize any control inputs.
Spirit 2 Software is 3.3.3
Here is a Video : https://youtu.be/lX6PCOmUaZs
What else can I do ?
At fist look in your logfile, the swashplate doesn't right initialize ! Read there what it says -
Have you choosen the right protokoll ?
Can you power up your system with an battery instead of the ESC-Power, maybe it is an problem of the ESC and your throttle range isn't correct - look in spirit settings what do you see in diagnostic tab, are the bars moving by moving your sticks ? Can you make a short video what you see in spirit settings ?
BR
Matthias
Edited 05.03.22, 16.16 Uhr
Johannes Fölsing
Hello, I have set SRXL2 in the Spirit. In SRXL2 mode it initializes correctly. I don't get as far as adjusting the gas in the connection to channel 1. Nothing moves in the diagnostics menu. just by connecting to Bind / dat /srxl 2
try it with a battery and without the spirit - for example only the AR6610T if its correct bound to your transmitter (constant shining), that's the only thing I can say - and your initialization is not correct (tilting swashplate) - As said before put power only to your AR6610T an bind it correctly to your transmitter, if here the orange light is shining then the binding is correct and it also works perfect with spirit -
BR
Matthias
Johannes Fölsing
Hi, but the binding also works with the Spirit without any problems. in my video both receivers are bound. They shine permanently. I can still try to bind the receiver with a battery. Binding isn't really a problem. binding works. but the helicopter does not initialize despite the bound receiver. That's my problem. many thanks for the help !
Update :
I have now tied with the battery, but the Spirit does not respond to any inputs. later I show the settings in the Spirit. I don't think that's wrong, since it works with the SRXL2 port alone.
Last edited by Johannes Fölsing on Sat 05. Mar 2022 19:03:08, edited 1 time in total.
