FrSky Integration with Ethos, S.Port & F.Port
I mean F.Port, FBus is not supported with any Spirit unit yet.
F.Port was supported only with Spirit GT until now.
Sorry Tomas,
I has made an false satement I have deleted it because you have referred to Spirit II, Pro and mue Spirit with FrSky integration cable - my fault
Matthias
We also made small improvement for S.Port that will help ACCESS operation. But integration support with EthOS and S.Port can't be enabled by us in any case.
Now together with FrSky we were able to resolve issue that was present with some ACCESS receivers for long time with a random loss of sensors.
tysonfromcanada
ZeXx86 wrote:If someone is interested we have working F.Port on all Spirit 2, Pro, micro with FrSky integration cable.
So telemetry and integration will work also there from now with OpenTX, EdgeTX and EthOS.
I'd like to give that a try - I have a heli I'm setting up now with a spirit 2, x4rsb (can run f.port firmware) and the integration cable that I can test it out on - currently control + telemetry is working via sbus+s.port and so it won't take much to switch it over and try it out. I also have an rx4r-access that I can try it out with.
Thanks,
Tyson
Dudemeister
So, I assume this is happening as of version 3.4.4 of the Spirit firmware. Perhaps a bullet point should be added to the description, because when I first read it, there was no mention of this.
This is not included in 3.4.4, but 3.4.5 that we are working on.
Dudemeister
ZeXx86 wrote:This is not included in 3.4.4, but 3.4.5 that we are working on.
OK, so maybe you should have said that, because the way you said it (we have working F.Port on all Spirit 2, Pro, micro with FrSky integration cable), it sounds like it's working right now, and some people might have already flashed their receivers to F.Port only to find nothing works right now.
It is working now. For this reason I said that anyone can tell me and we can provide this firmware.
Loetefix
Of course we are interested in the firmware. It is the only way to get integration in ethos with the spirit II .
STC...
I have tested the LUA Script 3.4.4 with my x20, the integration is now stable, there is no hang up where you had to turn off the transmitter.
But the collective pitch for bank 1 and bank 2 can still not be set.
