Firmware Download
Heliman550
Hi there, I downloaded an update for my Spirit Pro firmware and received the file (spirit-fw-2.4.1.man). This wasn't recognised by the newly updated Setting Software so now my T-Rex 550 doesn't work until such time as I get the correct file format (.4df).
Regards,
Heliman550
TomasN
Heliman550 wrote:Hi there, I downloaded an update for my Spirit Pro firmware and received the file (spirit-fw-2.4.1.man). This wasn't recognised by the newly updated Setting Software so now my T-Rex 550 doesn't work until such time as I get the correct file format (.4df).
Use Google Chrome or Firefox for downloading instead of Internet explorer. Or rename downloaded file.
Heliman550
I tried renaming the file but it didn't work.
Regards,
Heliman550
Heliman550
Hi there! Are there any Spirit team members to help on this????
Regards,
Heliman550
the only thing you have to do is to rename the file "spirit-fw-2.4.1.man" to "spirit-fw-2.4.1.4df". Then it will work.
Make sure that you are using Spirit Settings 2.4.1 and that you are in the Update tab.
Heliman550
Thanks, I did this and it didn't work.
Regards,
Heliman550
Please make sure that the extension you are changing is visible in the OS. By default extensions are invisible.
So the result is probably: spirit-fw-2.4.1.4df.man which is wrong too.
Make sure that the extensions are visible in your OS (can be configured in the File Manager).
Alternatively use other web browser (not Explorer or Edge), all other web browsers will work well and the file will be downloaded correctly immediately.
There can't be other problem - if the file has really 4df extension, then it must be visible in the Spirit Settings/Update tab (not Backup).
If I am correct, the problem is that you can't see the file, right?
Heliman550
Hi, thanks for your extra feedback. I can't look at it until tomorrow (10.06.17)
Regards,
Heliman550
Heliman550
Hi there! Apologies for the delay............lots to do.
I resolved the issue by using Chrome for the download. Renaming the .man file from the Edge/Internet Explorer didn't work and every download I tried was designated .man
Thanks for the help on this.
Regards,
Heliman550
GaryCam
I did the same thing , my spirit is dead now not a bit of power in it so either somebody can reboot it or I'm up for a new unit...
Any Spirit team there to help on this ...
Thank you..
