Wave receiver telemetry - usable with 3rd party sensors ans a common telemetry protocol
Sepp62
Currently with Wave receivers, there is no telemetry. Spirit units are restricted to just one ESC telemetry connection and support a limited number of "variables".
Desirable would be i.e. the following sensor types:
- Motor temperature
- Single battery cell monitoring
- Air-Speed (Pitot tube)
- Tank fuel gauge
- RPM sensor
- Backup-Guard active signalling/alarm
- Battery selector (with battery pack identification)
IMHO there will not be a satisfying buiness case for spirit proprietary sensors and a proprietary protocol. So my whish is, that Spirit will provide telemetry connectivity for one of the wide spreaded telemetry protocols.
Radiomaster just released a couple of sensors, which also can be daisy chained. Which means, that just one serial port is occupied in the receiver for all desired sensors. (HoTT also is very common with a large number of available sensors and sensors also can be connected in parallel). My guess is, that these sensors will be priceworthy and available in short time. Also DIY sensors will be connectable via this interface (CRSF) and each sensor provided by the community will also be usable for Spirit.
See: https://www.youtube.com/watch?v=ICXLDRpYn9I
we will be releasing the most of these sensors (and more) within following weeks too.
Each sensor you can buy is actually not open. So for getting the best performance it is always better if same manufacturer is offering own sensors with own protocol.
Same will apply also for Spirit.
Sepp62
will the Spirit telemetry interface be publically documented or is it possible to get a specfication for non-commercial use ? (possibly under NDA)
Yes, it will be definitively available publicly. We have no need to make it private.
Sepp62
That's nice to hear!
I am looking forward to the protocol description :D
Sepp62
I made a servo-extender/telemetry protocol converter which is currently running for Jeti Ex Bus. It is also capable to convert telemetry protocols.
If I had a protocol specification for Spirit/W1, this would also work on a Spirit system. In case of success, I would make it open source to have a reference implementation and a handy tool to use Spirit also in scale helicopters. This is the corresponding repository for Jeti: https://github.com/Sepp62/JetiExBus
AdrianR
ZeXx86 wrote: Fri 30. Jan 2026 11:49:45 Hello,
Do you currently have a timeframe for the sensors? One of the reasons I use Jeti is the arrary of sensor that they produce for their system. I have a Wave TX but still prefer use Jeti at the moment due to the battery monitor sensors (each cell is monitored)
Thanks Adrian
Sepp62
Pushing this topic again to the top.
With release of the QML interface, custom and DIY sensors are getting more and more attractive.
So having an interface description of the wave receiver protocol would be really appreciated!
