Hi Guys
I got this Spirit II last year but it has never functioned right, I think? I just noticed it lately trying to do a setup on my gasser.
On my T-REX 500, I was able to cheat in the radio to get the 500 to fly, but not the greatest.
This is the problem that I have when I am in the recovery mode or setup wizard when I go to the limits page and adjust the pitch range, I can adjust all the pitch range I need and more, but once I'm unplugged for the PC and reboot the unit the pitch never goes past 5°no matter what I do, pitch curve 100%, servo endpoints 100% the only way I can get a bit of more pitch is to go past, 100% in the endpoints, I am getting up to about 7°, not enough, it was all right for the 500 but not enough for the gasser.
PS I also have a Spirit GT on my Goblin and it works perfectly happy with it, very happy!
Default Spirit II Defective From New, I Think
for help you must give a bit more detailed information -
What receiver, what transmitter, what protocoll etc.
Make some pictures from your setup in the spirit settings and/or crate a .4ds settings file of your configuration in the FBL.
Post the file here in the forum (attachment) -
Another question why have you not informed the costumer support that your FBL is not working correctly ? Why have you waited so long to do something about it?
Receiver, Futaba R2008SB, Transmitter Futaba T14SG on 2.4 S-FHSS using S-Bus
"why have you not informed the costumer support that your FBL is not working correctly"
I had it on a T-Rex 500 and by cheating in the radio I got it to fly OK not great, I really noticed a problem when I wanted to set up my Gasser helicopter, that's when I saw the problem just lately, need more than five to seven degrees on the main blades to fly good, I all so have a Spirit GT on a Goblin 700 all most the same setup it is perfect!
- Attachments
- spirit-log-2023-10-03-114340.pdf
- (59.21 KiB) Downloaded 327 times
please share your Spirit Settings file (4ds from Backup tab)
You shared only PDF log. The problem will be related just to the settings.
I am really not good with this PC stuff, I tried to download the files and I can't do it, if someone wants to do a screen share setup, give me a time and date and I'll set everything up, maybe we can get the information you need that way, if not, I will send the unit in, to Spirit to get a look at, I will pay the shipping it is better then a non-functioning unit.
Thanks John
Thanks John
